I had a small quarter sized oil leak on the garage floor. I know it doesn't make sense, but after I changed the oil, put in Mobil 1 0W-40, the leak stopped completely. This would lead me to believe that the drain plug was loose, but this isn't where it was coming from. Anyway, the thinnest oil available stopped my leak. Strange I know.
Also, I was worried that I had a IMS bearing going out. So much so that I was talking to Jake Raby with Flat 6 Innovations. I was scared to even fire up my car. When I had it apart to do the 60K service, I ran the engine with the covers off and could not hear the sound the way I could from the cabin before. It dawned on me that I had glued up some insulation/sound damping material in the engine compartment, and perhaps this was making the strange sound. Anyway, I now do not worry about my IMS bearing.
2000 Boxster 2.7L, 60K...runs great, love it, drive it as often as I can. Just got a CE light, but suspect its the MAF sensor again. No biggie. I've had my car about 6 mos now and love it. I've put on about 2000 miles. B) B)
Very strange the leak would stop with ***** thin Mobil 1 0W40...if it reappears, I'd go with 10W40 or 15W50, depending upon your climate.
