I fill up the car, tighten the cap and drive. After about 30 miles, I will get
a engine light issue. I then tighten the cap again and drive for about three
days untill the light goes off.
Should I just replace the fuel cap or should I look somewher else?
the car is a 2007 997S.
Paul
Could depend upon what your CEL is for. I found that when I went to certain gas stations it would trigger the catalyst CEL. I assumed poor gas quality. I switch to a different station and it doesn't happen. CEL may not come on until halfway through the tank. It is consistent with a local, small town gas station.
Also, make sure you are turning the cap at least 3 clicks.
That is funny you said different stations. I will be
more careful where I fuel up. I always give the
cap three clicks. I tried giving it more one time
to see if that made a difference.
Paul
So I flipped the gasket. It had cracks on the
fringe. Looks like time for a new one.
I guess 3 years and 67,000 miles is enough
to beat the stuff out of the gasket.
I will order a new one tomorrow.
Paqul
Paqul
67k! Driving like it's meant to be driven. :)
