Will the exhaust from a C2 fit a C4S, or is there a difference between the 3.6 and 3.8 mufflers?
J
You may want to ask your question in the parts
number section and see if they have different
part numbers.
If the numbers are different then the parts are different.
Paul
part numbers.
Paul
Thanks, i will
I was just curious, lately the two local dealers give me different answers, and this was the case again
I finally got to look at the two sets, the mufflers are identical except the exit pipes where the tips attach are different. The S diameter is way bigger than the non S version
