2001 Boxster 2.7 RHD
Thanks to a great forum. You inspired me to service my own Boxster. Afterwards it would occasionally spew masses of smoke out the exhaust. Again, the forum led me to replace the AOS (which has cured problem). My small contribution is to suggest an aid to fitting the bellows with original spring clip. I tied the spring clip open with steel wire, the bellows slip on easy, then snip wire and clip springs tight - no strain on bellows or fingers. See attached file.
