GT3 CS 2004 - likely modified performance stats
Hi to all GT3 fans & greetings from OZ :D
I have a GT3 CS MkII - MY04 - last imported into Australia
Extensive performance mods done - detailed below - so interested in "theoretical" performance statistics etc
Particularly, with differential ratio lowered from 3:1 to 4:1, what will be the new:
- top speed - vs 306km/hr in factory trim
- 0-100km's time - 4.5secs in factory trim
Also - any other mods I should consider??
- apart from my own driving!
all the best
Justin
+61 419 297 297
MODIFICATIONS TO PERFORMANCE POST FACTORY
- motorsport differential with ratio lowered from 3:1 to 4:1
- lightweight, single mass flywheel
- Bilstein PSS9 2-way adjustable shock absorbers – height & damping rate
- 2 piece floating lightweight slotted front 380mm rotors
- Pagid yellow racing brake pads to front & rear
- Star motorsport exhaust
- catalytic converters removed
