On a 2000 911 C2, how does one access the windshield/headlight washer system components, i.e. reservoir, pumps, etc. I've removed the inner panel on the driver's side front fender and now see only a thick black plastic member running from the bottom rear to about the top middle. Does this have to be removed? The system has a leak that I am trying to identify and correct. Thanks. :renntech:
I'm pretty sure, the "thick black plastic" you seen under the left wheel well liner is the washer tank.
