I have a 2000 996 and need to know what pressures I need for the Low and High side to get a good temperature out on my ac @95 degrees F outside temp.
Edited by Mother
Got it thanks, unfortunetly did not work still blows warm I think I have a leak somewhere so onward through the fog I go.
Ive got a 99, 996 carrera, and i charged it with 134a refrigerant until the discharge temp of the air was 38' f.
The suction pressure was around 20 psi i think. can't quite remember. but if you go by the discharge temp, cant really go wrong.
