I have a 2000 S that has been lacking low end torque. It was suggested that I swap out the MAF. Well...
Currently installed in my car is 986.606.125.01
Pelican parts contacted Porsche with my VIN # and was told that I should be using 996-606-123-00
Reading Mike Focke's Page
Mike's MAF Page!
My MAF may have been changed and the ECU re-flashed to accommodate the new part.
Is there any way for me to tell if this has been done without the service records? I wish to replace the MAF but want to use the right part...
I have a Durametric scanner if that will help...
Edited by funkdefino
Your original MAF was a 996.606.124.00. Your car is egas (MY200 on) so 996.606.123.00 will not work in your car.
If your car now has a 996.606.125.00 or 996.606.125.01 then it has been reprogrammed for that (newest style) MAF.
You need a 996.606.125.01 for your car.
Thanks for the quick and decisive answer! That is what I suspected, but 2 mechanics and the local dealer here in Miami couldn't be "sure".
