I noticed today that when the car is moving there is a squealing noise from the rear driver's side wheel. I am assuming its related to the brake but I can't be sure. Is there a good way to troubleshoot this problem? I had the pads replaced less than 5K miles ago. It doesn't matter if I am braking or accellerating its a constant sound that gets louder the faster the car is moving.
Thanks for the help.
Jonathan
must be the brake dust cover. I had the same issue when I replaced my brake pads. It's hitting the rotors making the noise. Remove your wheel, bend the brake dust making sure you have a good clearance...make sure that when installingyou wheel back that you follow the correct procedure in installing it.
