when replacing the fuse on the alram module, 15A, is it required to get reprogrammed again? or just disconnect the negative cable on the battery? Just wondering because my alarm no longer works. I replaced the key's battery and still doesn't work. I'm just wondering if it's the fuse on actual alarm box located under the driver's seat. Thanks
jv:
That is very likely the problem, and easy enough to eliminate. Disconnect the negative cable and then pull that small 15 amp fuse from the alarm module. No reprogramming necessary.
Regards, Maurice.
jv:
Regards, Maurice.
Thanks, I'll try it tonight...
