Hey All
I was just curious what type of Bulbs or LEDs light up our instrument panel. I am talking about our guages, our buttons for A/C and radio. I was curious because I am adding a McIntosh Sound System and wanted to have the lights in the car ALL Blue. Are the LEDs just covered with a "condom" that emits that *****-yellow light, or is it different. Thank you
996 cluster for 1998-2001 has bulbs. LEDs are use in the turbo cluster and in the 2001 up Boxster. You can tint the lighting bulbs any color you like. Jeff
I have a 2000 996 and I also find the current bulbs not bright enough. Since mine utilizes incadescent bulbs, I thought I may try LED bulbs because they glow brighter, run cooler, and last longer. After some consulting with Loren, I found the bulbs in the Service Manual:
Bulbs for Instrument cluster are:
EBS-P/4-A 1.5 W
EBS-P/4-A 1.2 W
I also found a web page that makes LED bulbs for various applications including automotive purposes. The bulbs come in WHITE, BLUE, RED & GREEN.
Automotive LEDs
more specifically
Dash Board LEDs
Let me know if you find out whether these will work or not?
GOOD LUCK!
:lightbulb:
