I have a 99 Boxster that has the outside temp displayed in the instrument cluster. I just bought the stalk/switch for the On Board Computer (OBC). Does anyone know wheere or which plug in the steering column this switch should plug into.
Thanks in advance.
BillF.
Lexington KY
Thanks in advance.
BillF.
Lexington KY
Do a search for OBC hack. You will have to make up a wiring harness that plugs the stalk/switch to the the white plug behind the instrument cluster and ground the switch. like this obc hack or this obc wiring.
Thanks in advance.
BillF.
Lexington KY
Thanks for the direction I did the hack 2 weeks ago. It was relatively easy. this forum is truly an ocean of knowledge.
Thanks again
Bill. :renntech:
