I was wondering if the understeer for a stock 99 carrera is alot or alittle... I was going around 70-80mph accelerating on an on ramp corner and I was getting understeer. Wondering if it could be the wear on my front tires, but the tires seem to have some life on it. There Continentals and i have Michelin Pilots on the rear. So do the stock Carrera's have bad understeer? Or is it the tires?
Stock carrera's do understeer given factory alignments and tire pressures. Also given the fact that you have grippier tires in the rear will increase understeer.
