Hello All!
I recently purchased my 99 C2 with noisy Goodyear F1s (Yuck!). I love the feel of Goodyears but I cannot live with the noise.
My favorite tires are Potenza RE960AS Pole Positions as they serve their purpose very well with a longer tread life. Unfortunately, Bridgestone does not make the correct sizes for 17 inchers.
In researching tires I came accross a new model of Continental called the ExtremeContact DWS. The DWS stands for Dry, Wet and Snow. The treadwear rating on these tires is a 540! The limited reviews as of yet are excellent and Continental offers a 50,000 mile limited treadwear warranty. So, before I buy...
I accomplished some calculations on my tire dimensions for your consideration.
OEM
Front Wheel 7.5"
Rear Wheel 9"
Front Tire 205/50 17
Height 25.1"
Section Width 8.5"
Revolutions 825
Rear Tire 255/45 17
Height 25.1"
Section Width 10.2"
Revolutions 825 (Current speedometer is 6% off from the factory)
NEW
Front Tire 225/45 17
Height 24.9"
Section Width 9.2"
Revolutions 828
Rear Tire 275/45 17
Height 25.7"
Section Width 10.9"
Revolutions 811 (Speedometer will be closer to 3% off)
As you can see the OEM (v) NEW widths are 7/10 of an inch different. The heights are a mixed bag with the fronts 2/10s taller and the rears 1/2 and inch shorter, OEM/NEW respectively.
DSWs will not be as grippy as the F1s because of the harder material and deeper tread.
Wider and shorter tires on the front should increase over steer a bit.
Wider but taller tires in the back should decrease over steer a bit.
The DSWs still have a rigid sidewall as they are Ultra High Performance but my ride should soften a bit because of the extra tread and width.
I am not sure if Continental will offer the DSW in the 255 ratio when I purchase these tires in the near future.
I do not AX this car and never intend to drive it any other way then normal on the street.
There is a post on RennTech that addresses this issue with regards to auto cross but there was no follow-up on the decision made by the poster and results.
Has anyone used the sized tires that I am considering?
D.
  • 5 weeks later...
