Hi all,
This may be a noob question, but I am in position to obtain an '82 911 SC, which has the 3.0L. Is it possible to swap in (with fabrication if necessary) a turbo from the 3.3L?
Steve
*UPDATE*
I found a nifty thread on Pelican forums from a very knowledgeable guy who did the conversion with an old BAE turbo kit on his 3.0L:
http://forums.pelicanparts.com/showthread....ht=911+SC+turbo
Edited by maytime
  • 3 months later...
Hi all,
Steve
*UPDATE*
<a href="http://forums.pelicanparts.com/showthread.php?t=90065&highlight=911+SC+turbo" target="_blank">http://forums.pelicanparts.com/showthread....ht=911+SC+turbo</a>
Swap in a complete turbo engine or jsut add the turbo to the existing engine..??
The turbo engine would already be detuned/derated, <8:1 CR, in order to accomodate, make use of, the turbo's FULL boost capability. The easiest way to detuned/derate the existing engine might be to add the thickness of 1 or 2 extra head gaskets.
