Hi All
Been looking around for a 4 stalk and managed to find one with 3 stalks - wipers, indicators and cruise.
Mine currently also has three - wipers, indicators and OBC.
Is there a way of making a 4 stalk out of these and what's the easiest way ?
Cheers
Cheers, had advice that i can just attach my OBC arm to the other stalk with cruise. Just hope everything else will be ok as it's off a Y plate 01 car and mine is 04.
I doubt there will be a problem though ?
Little update, this is the actual stalk, hoping just to attach my OBC stick. What do you think peeps. It even has the part no. on it.
Cheers
It would be easist to remove the cruise arm from the new switch, and instal it on your 3 stalk mechanism on your car. You will still have to wire the car to use it, and have your cluster coded as enabled.
The cruise lever is integral with the switch unit, and can't be removed. The OBC lever is screwed on to the switch unit, and easy to swap over. You can see where it attaches in the photo with the white tag - the tag is attatched to one of the screw holes.
