As you may see from my past posts, I had a overheating scenario this weekend. I'm trying to track it down. By car has a new coolant tank a few months ago (latest style from Porsche), however I'm thinking that the coolant tank cap or value may be leaking.
Could it be that a new tank doesn't come with new cap and bleed value?
A new tank does not come with a new cap. That is a separate part. I believe the most current part number ends in "003".
A new tank does come with a new bleeder valve assembly, as that is an integral part of the coolant tank. Note that you can buy just the bleeder valve assembly as a separate part if that ever fails, and then install it into your existing tank.
Regards, Maurice.
