key matching using the PIWIS
Just follow the procedure in the service manual.
When you program a key you must have ALL the keys present. There are only 4 key slots available in the immobilizer - so max keys is 4.
When you replace a bad key you need the good keys so you know which key code is the bad one to program over.
If don't have all the keys present you run the risk of programming over a good key and leaving the bad key program in the immobilizer (wasting a spot or disabling another key).
