I have 1996 C2 Cab with a 6 speed. The shift knob from what I can tell is stock. I have lifted up the leather boot and to find that this is not a set screw to remove. I tried to simply pull off the know without any luck. Am I missing something, a clip, etc! :cursing:
The standard shift knob is just a tight friction fit - no set screw. You need to pull harder. You can also grab the knob and give it a good twist back and forth. Then pull. This expands the plastic sleeve that is keeping it in place. Like Loren says, watch out when it suddenly comes off or you can hit yourself in the face.
Aileen has done so many B&M installs that she can do it blind folded.
