Diving in my 2001 996 today and the CDR 220 display blanked out. The radio continues to work fine. I can switch from CD to radio etc. All buttons seem to function. JUST BLANK DISPLAY. I removed the display and re installed and still blank. Any suggestions?
Probably the backlight for the display. Use a flashlight and look at the display to see if there's anything there. If so, then probably just a small bulb inside the unit needs replacing.
thanks. buffed contacts plates. seems oxidation built up. LCD display working fine now.
