Thanks for the help. I was going to pull the plug in the pan that looked like a drain plug, but I was a bit leary. Now where is the fill plug?
So the check plug is the one in the rear of the pan right? I just have to find the fill one. Is the fill an allen key as well?
Thanks again!
Edited by jstbecauz
You need to read the messages again. What you say looks like a drain plug is the fill plug. That is why there is a round hole in the stress plate that is shaped like a triangle. So you can remove the fill plug through the plate.
I couldnt find the drain plug cause it was covered by a boat load of mud and the skid plate. After I changed it you could have mistaked the transmission fluid for 30 wieght. It was so black. Is there any way to flush these transmissions, not just drain them?
