As long as the wheels are 52 mm (7.5" or 8" front) and 63 mm (10" rear) offsets they should fit without spacers. The 10" rears with 40 mm offset will also fit a MY97 C4S.
Wheel size is usually next to the valve stem on the outwards facing side of the wheel. Porsche part numbers can usually be found on the inside of the wheel. If you can get the part numbers I can look up the offset.
