I just replaced my motor mount with Pedro's enthusiast mount. Everything went fairly smoothly. had to lower the engine a few inches to get a couple bolts off. This was on Monday night.
Weather has been rainy lately, so not good boxster weather. However, I've begun to notice a whine from the engine compartment. Not sure if this is just a harmonic amplified by the stiffer mount, or if it's a symptom of something wrong....
Far as I can tell, the whine sounds like a differential (or what a bad diff might sound like) , but it also happens at a standstill with the car in neutral. I think it might be a belt/pulley issue. The whine increases in tone with the engine revs., but not with wheel speed, so I doubt it's transmission/wheel related.
Any thoughts?
Peter
Disconnect the serpentine belt then start up, Has the whine gone?
Dont run too long without the belt in place as the water pump will not be driven.
This is very likely to be an idler
