The purpose of this thread is to troubleshoot this problem until I solve it. Even if I have to take it to the dealer do get it done. Step by step so hopefully nobody else has to for this problem.
Brief summary of why it is not the MAF.
-Old MAF 986 606 125 00 car was running ruff P1128 P1130 codes popped CE light ( fuel air mixture lean )
-Dealer & I checked for Vacuum leaks & found none.
-Replacement MAF 986 606 125 01 car runs good No codes or CE light but Idle is hunting.
- Dealer states no software upgrade is needed for replacement MAF. and suggests the New MAF is bad, since then 3 New replacement MAF have been put in and hunting is still present.
- For kicks I put the old MAF back in and the idle is fine but old problem is their rides ruff and old codes pop up again.
- Unhooked the car overnight to reset any old MAF parameters in ECU (Cause of a hood lock out but that is a separate thread)
After I fix the hood cable I will start fresh on the hunting Idle problem. Special thanks to TP, Loren, and Scott for their help. Scott has given me great materials and there is an "oil separator" lead that I need to dedicate more time and attention to.
wish me luck! :unsure:
J
Edited by porscheneer
WOW, I was about to embark on a quest, I think it may have been cut short. And gladly so.
TP I couldn't find any DIY for this is there any Diagrams or instructions with regards to the Throttle body/ Idle stabilizer.
:thumbup:
On another note, if there are newbies to the site reading these posts as I was a few weeks back, make a contribution these guys are the real deal, great help and its all on good will.
Thanks guys :clapping:
AND WOW again, so did you try to clean the throttle body/ Idle stabilizers and it didnt help? than you tried the oil seperator did you DIY?
is there any illustrations or instructions I can get my paws on
because you did an engine swap right
i did not clean the throttle body / iac valve.
i had been noticing rev fluctuations for quite some time. no codes were being thrown. one friday, just driving along, a cel came on. i took it to the dealer (carlsen), they traced it to a bad oil separator - and replaced it.
i asked them to clean out the iac valve. they told me they could not find it (???). during the next diy session i intend to clean the throttle body / aic valve.
Thats odd I thought the IACV was part of the throttle body?
Anyway is there anyway to isolate the oild separator to make sure?
if you have the part # handy was it 996 107 080 54
some people call it an oil breather?
Thanx for the insight Troomi
and one last question was this true in your case
"This condition will usually be exacerbated with the A.C. on"
cause mine was not either
J
the part number for the oil separator is 996.107.023.03 - i have a 2000 box s. i believe that the iac valve is part of the throttle body, please verify with jeff lopez (a.k.a. tool pants).
i rarely use my ac.
forgot to mention - source your parts from:
sunset imports
4050 sw 139th way
beaverton, or 97085
800 346-0182
excellent pricing - no sales tax
It could also be this:
Usually the problem would be with a sluggish Idle stabilizer or also called an IACV. These valves can get corrosion in them and slow down until they get stuck and then cease to work. This valve controls the amount of controlled bypass air required to keep the car idling. These conditions change with load and the valve opens or closes to accommodate this. The valve is easy to access from its location on the side of the throttle valve housing. This condition will usually be exacerbated with the A.C. on.
It also could be your oil seperator leaking air into the system.
Scott
