Yes. This was a common swap when the 220 came out. The 220 has aux-in and the 210 does not. So people replaced the 210 with the 220 in order to have aux-in.
The 210 mounts in a metal frame. In order for the 220 to fit you need to remove the frame, and the 220 will slide in. The alarm contact is in a different location, but I forget what if anything needs to be done.
Thank you for the quick reply. If you think of anything else I sould be aware of (like making sure I have the activation CODE), please let me know.
