I need a little code help. My car a 2001 boxster 5 spd is not idling smoothly the lights and A/C fluctuate with the engine rpm. The voltage according to the durametric reader bounces between 11.8 and 13 ish with the engine rpm and the battery light stays on. I am also getting the code 9133 61 term low engine running. Any ideas or suggestions for further diagnostics.
Tarry
Edited by thtabe
How old is your battery? 4 years or more and it is likely the problem.
Have it load tested and also the specific gravity of each cell tested.
Ok the battery checks out as good. The voltage according to the durametric reader bounces between 11.8 and 13 ish with the engine rpm and the battery light stays on. Any other ideas?
Whats going to be the best way to test the alternator?
