Hi all, I am trying to cover the little missing / lost pieces from the work done and it seems I am missing a body plug from within the battery compartment cowl. it sits in the wall behind the battery, it is off to the right a little from the battery. It is roughly 3" in diameter. So if Loren happens to be online and wouldn't mind spittin it's part number off the top of his head, or if someone has access to it, I would really appreciate it. I talked with sunset imports and they had no luck looking it up. Thanks
99' C2 6spd.
That would be the one. Thanks again Loren, you have a gift for making things a little nicer. God Bless.
Jeff @ Sunset has it on the way! Many thanks.
Edited by ViolaGT3
