First off I'd like to say hello since I am new to this forum. I have a 2001 Boxster S 6 speed with 42,000 miles on it. I bought it last year with 22,000 miles so I have been doing a good bit of driving in it lately. Ok now onto my problem. I have done plenty of searches so I pretty much know what is going on but wanted to make sure. The car threw a CEL about three months ago with the code P1126 which I know means it's running lean on that side and the DME has richened it up all the way. I cleaned the MAF and it didn't help and as far as I know a MAF will through both codes for the left and right side of the engine correct? I also have "some" of the signs of a bad AOS. It has oil build up all around it and it seeping out of the intake tubes after the throttle body. I also have the whining noise at start up but it goes away after a minute or two. I removed the oil cap today with it running and it's sucking a lot of air in and the engine RPM's climb but it wasn't difficult to remove the cap. I have read that it is really hard to remove the cap if it's a bad AOS. So before I spend needless money what should I do? MAF or AOS? Thanks in advance!
Edit: I should also add that I do not get any smoke on start up unless the car sits for a few weeks.
Edited by Rated-S
AOS
on the twin theories that you'll need one soon anyway and you have oil seepage which wouldn't be from a MAF. Clean the throttle body too.
DIY guides are available here.
Thanks for the reply. Your website is actually where I went first and found out about the AOS. This is my first Porsche so it's a learning experience for sure!
