Anyone knows where to find 19" full slick tyres for track use ? Been looking for a while, seems only up to 18" available as far as my investigation concluded
Patrick
try tirerack.
www.tirerack.com
Paul
Well, Paul, i did that already but no 19" shows up, except the Hoovier semi-slick , not much different from Michelin Pilot Sport Cup.
Just wonder why only18" full slick available, std and widely available for Carrera Cup, but not even 19" seem do exist, while 997 GT3, GT3, TT, GT2 are all on 19" wheels..... Economic crisis oblige...
I keep searching.
Patrick
The TRG racing crew put 18" tires on all of there
997 cars.
Paul
Thanks Paul. yet can a 18" wheel be fitted with on 997 GT3 RS with PCCB ? It seems OK in the rear, but in the front, apprently seem too crowded.
What wheels & full slick size would you recommend, as i will have a specific set for the track
original
Front Stock come with 19 x 8.5 with 235/30 tyres.....
Rear Stock 19 x 12 with 305/30 tyres...
thx
997 cars.
Paul
original
thx
There are quite a few race wheel manufacturers who build 18" Porsche size wheels to clear the big brake kits. Check out CCWheels.com, they are some of the best and have good prices and excellent customer service. Their CCW C14 or C12, or C10 in an 18" x 9" wheel with a 53 offset will easily clear your 997 PCCB brakes.
I believe Champion and HRT also have 18's that clear the PCCBs, as does BBS and Chargraphic's GT series.
Check out CCW's new LM series of 3 piece wheels. You can get an width up to 16" with 16" 17" and 18" diameters only. They can build them to any offset that you desire. For a GT3, a brand new set of these go for $2,800.00 with the 12" x 18" weighing in somewhere between 20 to 21 lbs. The front 9" is probably around 18 lbs!
I cannot say enough good things about CCW. I personally run their 18" x 9" with a 53 offset and 997 PCCB's - no problems!
Stephen
997 cars.
Paul
original
thx
Stephen
Thanks Stephen, you are lifting some of the mystery.
Considering that i will build a specific set wheel + tyres, for TRACK PURPOSE ONLY then I am thinking:
18 x 9" Rim (CCW or Champion) with 265ZR35/ (Front)
18 x 12 Rim with 315ZR30 (Rear) or 325/30
with the lightest wheels types, maybe Champion RS28 or RG5-B or even Dymag Carco, and tyres either full Slick or Hoosier A6
What tyres types are you using for the track ?
patrick
Sounds like you are on the right track. Buying
track tires makes things complicated. Some tires
are qualifing tires
and some run thru alot of heat cycles. I would go with Hosier
for your first set. They stay good thru alot of heat
cycles. If you have any questions just call TRG. Tell
them you have some racing questions concerning wheels
and track alingment.
Paul
Thanks Paul, will do.
I live in Shanghai, and my car is serviced on....F1 track there, so car is mostly used on that fantastic track, so i can swap wheel tyres anytime conveniently. I see there GT3 cup asia here service on 18" wheel/tyres with Michelin but none using PCCB. Your previous note anyhow gave me hopes.
In contact with Champion/rim and TRG for tyres....
For the story, on F1 track shanghai (5.5 km). the laptimes are
F1 cars : 1'35" best
GP2 cars ; 1.45" best
Formula Renault:2'06" best (which I drive too, at 2.09)
Porsche Carrera Cup / 460hp(with Slick); 2'12"
My GT3 RS on MPSC: 2.29 "
All Ferrari 430 on MPSC :> 2.30"
Looking at the difference from my GT3 RS with Carrera Cup, i am sure with the slick and light wheels, can improve by more than 10s , the rest being
power, suspension, aero, weight.
will tell you later.
patrick
Stiffen up the rear swaybar and get the wheels aligned for
track use. There is 3 to 4 more seconds.
Paul
Hi Paul, finally i contacted CCwheel.com, i was told they got 18" wheels can clear OEM PCCB (C10 model) , and 18" are the max size for full Slick Tires. They recommend full slick Hoosier R100's series 18" x 320 19 x 250 for rim 18" x 12" R, 18 x 9" F
Still checking if that work. I have abandonned my quest for 19" full slick...
Patrick
