Hello everyone I'm new to the site. I can tell you overall this site is amazing! I'm trying to sell my 2001 Porsche boxter. However my check engine light is being displayed. I ran the OBD2 reader to it and 3 out of the 4 Senors need to be replaced. I ordered universal oxygen senors that have 4 wires instead of the actual connector. Do you guys think i can still go through with the procedure on replacing the sensors with out the connectors?
I have not had luck with the universal kind of sensors, but others have. It might have been that - bad luck.
You snip off the connector from the OEM one already installed and reuse the connector by wiring it to the new sensor using the directions in the kit.
