So I was thinking of changing my Gear box oil, my 996 6SP has 73000miles nearly on the clock,
new motor about 3000mile's ago. But I have been told by my indy to wait because Gear box oil change's it can sometime's cause problems?
Is this true...
Whats the process, is it a big job to change and whats the best Transmission Oil to use.
Thank's to all in advance.
Edited by JamesD
What problems would fresh fluid cause? IMO, that's Bull. I've heard this wives' tale before, but mostly regarding automatic transmissions.
Factory interval is 90k. For my own peace of mind, I cut that in half. Use the factory fluid.
If I drove an automatic 90,000 miles with original fluid, I would either not chenage it, or if compelled to do so, only change out about halpf of it at a time and the other half only after another 6 months or so if I find there has been no negative effects of the first change.
If you think its BULL, then go and change it all and the filter. IME, you have about a 50/50 chance that your transmission will not function as designed.
Let me clarify:
So I was thinking of changing my Gear box oil, my 996 6SP has 73000miles nearly on the clock,…But I have been told by my indy to wait because Gear box oil change's it can sometime's cause problems?
If I drove an automatic 90,000 miles with original fluid,…
We’re not talking about an automatic. His indy told him - well, read it - that's what I am saying is Bull.
Let me clarify:
You can change gear oil at any time and mileage and it will all be good.
Well guys,
I think my indy think's, it's not nessasary not before 90K anyway
I have heard this tale before, (if it's not broking) but only for AUTO's mine's a MANUEL 6SP :D
Anyway I got a recondition engine installed about 3k ago, so I wonder if it was done then?
(don't think so different garage at the time they where cowboy's)
Is it a big job to change the oil on a 6sp box???
