Is there anywhere I can find out the factory specifications for the standard Boxster 987 (2006) Wheel Alignment?
I need to do an alignment for my car, however my car is no longer the factory standard as I had the following items changed -
- Eibach Pro Kit
- 19" Carrera S Wheels
- H&R 7mm/14mm Spacers
Will it be possible to get my car to the factory standard specs without having to change any of my items?
How do I let the guy at the alignment shop know since he does not have the software details of my car alignemnt specs?
One more thing, I heard from some guys that it's better to sit in the car whilst doing the alignment, and if possible fill up the tank too. How does that affect the alignment, if it affects at all.
Thanks.
Porsche 4 wheel alignments are calculated with FULL fuel tank and NOBODY in the car, the standard specifications are not always feasible with modified suspensions, compromises have to find if it is the case.
thanks for your advice. given that the guy at the alignment shop doesn't have any clue on what specifications for my car with the modified parts, could you or anyone give me an idea of what the specifications should be roughly like? could I take it from the specifications for Cayman instead? Our cars drive with the steering wheel on the right hand side, will it be of any difference from the left hand ones ? thanks
From the service manual on wheel alignment:
"The following values relate to the empty weight, i.e. full fuel tank, vehicle with spare wheel/collapsible wheel and tools, but without driver and without additional weights!"
There is no difference between aligning a LHD car and a RHD car.
Porsche does not have any specs for 3rd party suspension parts - the owner is on their own on this.
thanks Loren
i just needed some figures from anyone who has a similar set up so that it could serve me as a guide as to what I can expect from the alignment to give my car the optimum handling and minimum uneven wear on the tires.
  • 7 months later...
The settings are different depending if the car has PASM (lower ride height) 17, 18 or 19 inch wheels and spacers etc.
The camber , toe and castor are guidelines , so its not to say you need to follow them. A good alignment shop will know the amount of camber to put on a normal road car to prevent excessive inner shoulder wear of the tyre. The "toe in" on both the front and rear is also dependant on how much grip is required and the traits of road you drive on (motorways or twisaty side roads, race circuits etc). I have some data for my own 987S (MY2005) I can post up, but its only a guide. Lower front and rear springs will also alter the caster on the front , so the toe and camber may need corresponding adjustment .
