can someone please point me in the direction of a guide that will show me how to replace a dash glob (one behind the clock) or failing that, give me some breif steps to follow?
I have searched and found a similar thread but the answer was to look at other guides (that I cant find....)
Thanks in advance,
Sam
Sam,
If a globe is a bulb and your car is a 986 with a digital clock in the insreumenr cluster, I don't know if a bulb will help. Nonetheless you need to remove the guage pod. Popping out the emergency flasher button will expose a screw on the rt. On the left pop out the little microphone cover exposing another screw. Remove both screws and the pod should come loose revealing all bulbs.
Regards, PK
yes sorry - globe is aussie for bulb :)
Its a 986 RHD with the digital clock in the instrument cluster. I can see its still working, just not illuminated like the other two digital displays. Thanks for the location of those two screws, that was exactly what I was hoping to learn!
Sam
No prob. Sam,
I doubt you'll find it back lit. I always thought they were self illuminated.
Regards. PK
Had the same problem and tried "the thump" method
Tools required: Fist
Procedure: Bang fist on top of dash several times until the back light becomes illuminated
Picture attached of back light prior
Thanks guys, I should be fine from here now :)
Sam
post-32525-0-87282800-1293409486_thumb.j
