Elo, after admiring it for years and searching/reading for about 2 months finally i am in process of buying cayenne turbo in Dubai imported from Italy just a short while ago.
I have searched a lot but no luck getting full report like carfax or AA in the UK
i can run VIN decoder which shows basic details but i require full report
please paste links if you know any.....
VIN: WP1ZZZ9PZ4LA81586
enough respect
Service history can only be obtained through a dealer/OPC.
An option history can be obtained through a dealer/OPC or by being a Contributing Member here.
Thanks Loren, as you can see this is my 1st ever post on this forum, i went through almost all threads regarding cayenne on renntech and other relevant forums during my 2 months long research.
Please telme how do i get history by contributing here?
i also need to know if there is any theft/accidental recordon this VIN
Thanks so much
Thanks so much
Contributing Members can get their car's factory options but only Carfax (or some company like that can look at legal records - which are different in different countries).
Thanks so much
so, can i get the factory options list please
Thanks so much
Yes if you become a Contributing Member.
Just click on the Donate link at the top left or any Donate button at the bottom of any page.
Thanks so much
Oh i see, i will have to setup a paypal account......
Thanks so much
No, you can also use a major credit card.
Thanks so much
not working, maybe coz its locked by my bank to use on the internet...will check tomorrow
i know the options anyway....could you gimme sample report?
Is it possible that the 2005 model year having VIN and Porsche data sheet saying 2004?
what does the VIN says on 2005 model manufactured in 2004?
how do i find exact month and year of manufacturing? its not on data sheet
Build date is very often in the year before the model year.
Porsche starts building the next model year in July each year. So production of MY2010 will begin next month.
Look on the drivers door for Porsche sticker - in the top right corner of the sticker is your build date (not necessarily your model year).
so what i understand is that if build date is later than June 2004 then it can or cannot be 2005 model?
so how do i find if build date is after June 04 and is 2005 model or not?
when did Porsche update parts and software, i simply do not want to buy anything which has common faults like vibration, coolant pipes, driver shaft etc?
Thanks Loren for your continues help :)
No, just the opposite - if the build date on the door is say 8/04 then the model is a MY05.
If the build date on the door is 6/04 then it is most likely a MY04.
I own a MY99 Carrera - my door sticker says 5/99. In July of 1999 Porsche started building MY2000 cars.
cheers Loren, just to make it clear, if build date is 8/04 and 10th character on VIN is "4" then its a MY05 model?
No, that would not make sense - but then we occasionally see a car with mismatched VIN and build dates. I've seen two like this and both were made in 2003 and 2004.
