Left turn signal does not work front or back, bulb ok and when I put the Hazard lights on they all work. When I put the left signal on the relay buzzes alittle when applying the right turn signal no buzzing occurs?. Any suggestions
most likely it's the relay under the dash.
usually buzzing means fried relay,,,
I will get another one and see.
Replaced relay and bulb and still same thing. I tried just jumping the bulb BRN to ground and had not results.
