Hello folks....,
A friend of mine is the owner of a 1999 Boxster and he is in need fror a cluch replacement
The questions are
Is it hard to do and how many hour the dealer will ask to replace it
Thanks in advance
Robert
1999 Boxster
Tiprtonic
Hello folks....,
The questions are
Thanks in advance
Robert
1999 Boxster
Tiprtonic
I believe R&R of the transmission is about 7 hours. Then about 3-4 to do the work. If you call your local dealers/specialists, they will probably give you a rough estimate. My info comes from a local specialist. Be prepared for a wide array of answers, though... I suspect you will hear a $300-$400 difference depending on who you call.
