Hi some technical info is needed here...
Obviously the drive comes out in a different direction in the 996 box to that of the Boxster. In other transaxles there is often an option to reverse the Crown Wheel and pinion positions to switch the drive direction.
Has anyone stripped a 996 C2 gearbox or that of a Boxster to see if this is posible ???
