I measured the front rotors on my '02 C4S today and they are just below the min thickness of 32mm. Can anyone recommend a source for reasonably priced slotted rotors for this car? By reasonable I mean about the same price as OEM.
TIA
Try www.brakeperformance.com for slotted brake rotors. Their prices are for a set of 2, so the prices may seem high. C4S brake parts are really expensive due to the big red brake system. I just replaced by brakes/rotors/sensors/bolts/etc with PORSCHE OEM and it ran $1500 at my indy.
I decided to stick with OEM as I've had good luck so far. Rotors were $153.92 each from Sunset Imports. Caliper bolts, spring kit etc were another $60. Will do the work this weekend.
That's a fantastic price on the OEM Porsche rotors. Better to double check that you are getting C4S brake parts and rotors, because they are much more expensive than the straight 996 brake parts.
