Lowered 1" w/Eibch springs now the mech. can not get past neg. 2 1/2 degree. Hence chewing alot of tire. :soapbox:
Thank you again for the help. Question When I put the springs on the rear the bolt with that witch you set the alignment by came out easily. The other side I had to beat out and back in, This just so happens to be the side I am having a issue with. I just mentioned that to the mechanic doing the alignment. He said somthing may be wrong with the bushing or something is bent.
