does anyone experience a bit of vibration through the stering wheel wen acelerating hard on the gaz caynne turbo ????? or is it torque power ??
Edited by malcolm lloyd
I'd check tire pressure first and then re-torque the front wheels. and check tread wear patters for uneven wear, cupping, or flat spots. They are easy. Flat spots from sitting in garage for a few days uasually disappear when up to temp. Then balance and alignment. Not hard but not exactly cheap.
Sometimes you can move wheels to isolate problem. Or borrow known good ones.
