I have had the check engine light come on and when I plug the OBDII reader in I have error code 0134, which is for:
"Oxygen sensor ahead of catalytic converter (cylinders 1-3), interruption of signal"
I have not yet been under the car since changing oil and plugs, and don't recall if the ignition wires are numbered.
Could someone tell me if cylinders 1-3 are on the driver or passenger side?
Thank you.
John
1999 Boxster
