Where can I get detailed information on DME scan? Understand it has 6 ranges and believe it has to do with engine revolutions; how many times the tach went over X value. Not 100% sure though - have done a bunch of searching on the Internet becoming up blank.
Help?!? :unsure:
I have not seen them published yet - but I'll keep an eye out for them.
I suspect hat the 997-1 ranges will be very close to the 997-2.
The 997-1 DME records the following rev ranges:
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 3: 7700-7900 RPM
Range 4: 7900-8400 RPM
Range 5: 8400-9500 RPM
Range 6: 9500-11000 RPM
Thank You!
