hi,
i have gearbox problems with my 996/2002. shifting is not smooth, every gear change makes a interruption...
is there anything to adjust/lube/fix/control on the mechanic from the shifting knob to the gearbox?
are there any DIY's or porsche service/maintance instructions available?
thanks
The gear change is operated by two cables that move a lever on the transmission. The only adjustment I am aware of is at the shifter. Porsche has a special tool that holds the shifter in a neutral position and the cables are adjusted with no slack at that point.
Did anything happen that could affect the cables? If not, this is likely an internal transmission problem.
