My driverside window gets really slow about halfway up. It's considerably slower than the passengerside on any given day. Sometimes it rolls halfway up and then goes back down again as if something is blocking it. It's very inconsistant when it does it but it seems that when I roll both windows up together it does this.
Does anyone else have this problem?
Nazz
There was an updated window motor that is described in TSB 1/99 6454 Modified Power Window Motor (dated 4-29-1999) that describes a similar problem. You can ask your dealer to check PCNA records (using your VIN) to see if your car has had or needs the TSB fix.
