Can you tell me what tool or the size of the Torx is required to remove the large and small screws that hold the rotors in place. On the front rotor there is a large Torx screw (part number: 910 282 01 which I am told is a T-50. That same T-50 Torx screw is on the rear rotor. Also on the rear rotor is a smaller screw (part number: 910 380 01) which looks like a 12 point Torx but I am not sure. And can you tell me the torque values (one more time for both of these screws). Thanks. :cheers:
