I have a boxster with no engine, no transmission, no dme and no dme harness.only have harness coming from dash to the back.
i am getting ready to pick up a salvage 996 from a friend for $3500, car still starts. not e-gas.
here are my question once i obtain the 996.
1. can i use the dme and dme harness from his 996 in the boxster or do i have to do the whole harness swap from cluster all the way back to rear?
do i still have to have it reflash for security bypass?
2. i know i'll still have to find a tiptronic transmission for boxster to mate with the 996 engine and sell the 996 transmission.
and buy a couple of mounts. i won't need spacer for the mount for my project because the whole engine compartment lid area has been
chopped off.revealing only the frame of car.unless somehow i can turn around the whole engine and transmission like in a boxster and make it
work somehow,then i'll be able to drive backward real fast,lol.
3.dropping in a 996 without the old engine is gonna suck, what parts do i need to obtain, i have tod write up but he has an old engine and he is using
his boxster dme. but if i have the whole 996 car what is needed to be remove to complete the swap?
here is the picture of my project i am building.
As you can see in the first picture the entire boxster engine compartment is gone.
Why did you post this again - it is already in the Boxster DIY section.
Please re-read the board Guideline/Rules that you agreed to when you registered here.
"Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
This thread is closed - please use teh thread in the DIY section.
This topic is now closed to further replies.
