Just finished changing the Brake fluid on my 99 Boxster. When I was bleeding the brakes (using a pressure bleeder @ 20psi) I was unable to get any fluid to come out of the outside bleeder valve on the Right Rear Caliper (besides a little seepage around the threads). The inside bleeder on the same caliper bleed normal. Do I need to rebuild the caliper or do you think maybe just the bleed screw needs to be changed?
The bleeder screw is in most cases the culprit, but to find that 100% out, you should remove the bleeder screw and take a closer look.
I think you're pushing the limits at 20 psi...
But I agree, your bleeder valve (or port) is clogged somehow.
Edited by jmatta
