Can anyone recommend a high temperature adhesive that I can use to re-glue the rubberized engine isolation attached to the top sides of the engine compartment? Last time I had my engine cover off, I noticed that it was becoming detached, sagging down and touching the intake manifold. This in not on the engine cover, but rather the engine compartment itself.
Terry
Terry
If your talking about what I think your talking about (above the engine hatch) most will say replace the stuff. Probably right. If not, you don't need anything high temp. a good contact cement will work If anything does. Think 3m.
Regards, PK
Edited by pk2
