I had a check engine light for a couple weeks and then went out. The Boxster started blowing smoke from the exhaust and running rough. I replaced the AOS and the engine is now smooth and smokeless. My check engine light is now on again and is showing codes:
P1128 Current
P1132 Pending
P1125 Pending
P1130 Pending
Any Ideas what to look for?
Looks like a vacuum leak and those codes are often the precursor to a failed AOS or its boot. Since you've already replaced the AOS I'd clear the faults and wait to see if they return. If they do you may need to preform a smoke test. Do you know anyone with a smoke machine?
