I have a 1984 Coupe with leather dash. The leather has shrunk and has also warped the dash pad. I have looked into the cost of replacing these items either through the dealer or World Upholstery, Pelican. Any other advice on a good source for replacment pad and leather covering would be greatly appreciated.
  • 2 months later...
I have a 1986 911 and warped dash - bought a plastic replacement for $109 on ebay. Had to cut the old dash quite a bit to remove the curve but it looks great. A friend had his re covered and he said my cover looks better. There are several vendors on ebay.
good luck.
have you solved you dash "pad" replacement yet? (sep 25) if not: i pulled mine, warped @ vents and leather shrinkage @ windshield. i found a guy in watsonville who works out of his house that repaired the warpage, covered in leather, replaced the 5-7 plugs, and helped me put it in for 350. great job call me if you need his # wayne (831-234-3209)
  • 6 months later...
take the front glass out to get to the screws.pop the gages to get to bolts.get a long extension open the front lid go under dash.its a pain but u gotta do it.just restored 84 grey market targa was all leather.took almost 2 years.
